I've just got a pair of these amazing headphones. I got them going with my Iphone in about a minute, but have now spent more than 2 hours trying to get my HP Elitebook WIN 7 laptop to work with them - it can't find the driver for the 'headset' bit ( the driver for the remote seems to work immediately) .
I cannot find any clear link on the Sony site to the specific driver - does anyone know where to look, or have any other ideas?
Thanks!
Phil
Hi Phil,
Welcome to the community.
Have a look at this page to see if it helps.
Thanks,
Pascale
Hello @pwhobbs,
the headset doesn't use specific drivers to run on a notebook - it uses a standard bluetooth protocol and should work as an audio device upon connecting.
May I ask what you mean by
which "remote"? Do you mean the touch controls?
And do you mean the audio by "headset-bit"?
If so do I understand that correct that you don't have audio but that you can control the playback?
- Nic
