flash player on tablet s updating
petsmart
Hi guys,
im trying to update the flash player from the market but it wont update throwing back a error msg.
error: your order is processing. Your item will be available in a few minutes
i cant uninstall it either as its not listed in downloaded apps but only under " all " in the tablet.
is this becuase its a built in App? any idea on how i can update to latest version?
i currently have 10.3 installed but would like 11.
thanks
Tags (1)
godzilla11
the new flash payer will give you problems with videos keep the old one for now and wait and see what android 4 brings when updated. i had to delete the new version
Thalamus.
Champion
Hi petsmart,
have you tried unistalling the update & trying again..:smileyconfused:
Settings > Applications > Manage Applications > Adobe Flash player
Then press Unistall updates.
petsmart
hi guys,
the old version is giving me issues and im struggling to play some stuff ...so i wanted to try the upgrade.
i cant uninstall it either..even after stopping process etc it just doesnt do anything.
might just have to wait for ICS to maybe fix the issue 😕
cheers
