Evening
im having an issue with the Vevo app. The TV (55XD9305) is hooked up to a Sony ES2400 amplifier. When I try to adjust the volume, the VEVO app kicks me out to the home screen. solutions appreciated.
Thanks. Gary
Solved! Go to Solution.
This is not caused by the Sony TV but is a bug in the Vevo app itself that came with the previous update. I have contacted Vevo and they replied that there is a new update as of today that will fix this issue. I have installed the update and it is fixed indeed. Thank you Vevo.
Hi there
Just tested this on my KD-55XD8577 connected to a Sony AV receiver (STR-DH820) and can confirm this problem.
I will report it to Sony and add it to the 'ever growing' list of bugs and issues.
If anyone has a 2015 Android TV, can you please test and reply back as I would like to know if this is unique to 2016 ATVs or not.
*** Congratulations @geeebeee72 well spotted - Hope you dont mind if I rename this thread slightly, just to make it easier or others to fin.
Same problem on a 2015 ATV - KD-65X8509C connected to Sony RHT-G11 Sound Stand. Changing TV volume, kicks you back to the Vevo Home page.
Hi
As an update:
Sony has reproduced this issue in testing using current and previous FW versions. It has been escalated up to the engineers.
