Walkman a55 senseme under Linux
felix.warneke
Neues Mitglied
hello everyone. i just got a new Walkman a55 to replace my quite old other one. the old one analysed music by itself for senseme functionality. i was a bit shocked to learn that the new one seems to have this ability removed!?! instead i now need (?) to install "music center". is there a Linux version for that? running the windows version under wine doesn't not work. this is highly disappointing. does anyone have any idea what i could do here?
thanks
2 ANTWORTEN 2
r_a_n_i
Hi @felix.warneke
Unfortunately I don't see any other option. You will need to do it on an Windows PC.
Here is the whole article:
https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0001691063.html
r_a_n_i
felix.warneke
Neues Mitglied
thanks. that is very unfortunate. I'm not sure what to do now. I'll probably try bringing it back and won't buy Sony again.
i can't understand why Sony decided to dumb down its newer devices while the old ones were able to do that. it is beyond me.
thanks again for the quick feedback!
