Error, power off
Sebachilexperia
Error, power off
Hola mi problema es que el smartphone se me apaga solo y tiene toda la carga de la bateria, claro que mi smartphone se me cayo el dia que lo compre y quedo con con la pantalla clizada, pero a dos mese de tenerlo habia funcionado sin problemas, a alguien le ha sucedido lo mismo? Que es smartphone xperia xa1 se le apague?, yo creo q es la bateria, pero mis amigos dicen que es porque se me cayo.
Hello my problem is that the smartphone is turned off alone and has all the charge of the battery, of course my smartphone fell the day I bought it and I am with the screen clizada, but two months of having it had worked without problems Has the same thing happened to someone? What is xperia xa1 smartphone is turned off ?, I think it is the battery, but my friends say it is because I fell.
gt
0 REPLIES 0
