I can't transfer video files from my phone to my computer
victorjohna
I am unable to tranfer videos taken in the mobile to my computer. I was able to do it earlier through Sony pc companion and mediago
12 REPLIES 12
Emir1
Hero
Hi @victorjohna,
Do you use the native Windows explorer in order to navigate the video file?
To do so, connect your device to your computer through USB > Press the Windows button + E on your keyboard > Choose your device > Navigate to the video file > From here, handle the file as you would any other file on your computer. Alternatively, you could open the file browser in Xperia Companion.
Is this where the error occurs, and if so do you get any error message? What does it read?
1adrian1
Have you changed the USB options upon plugging in to the PC, it'll be on charging only needs to be on mtp file transfer
victorjohna
Yes. I checked it. The photos I am able to copy and paste. But the videos do not allow to be copied. Earlier in Sony pc companion, these video files would not allow to be picked. But after we tranfer them to our library we can do whatever was needed.
Emir1
Hero
So you tried using the windows file explorer as I instructed? Do you get any type of error message or what happens when you try to copy it locally to your computer?
victorjohna
No message comes. When I try to  copy and then try to paste it in the computer, nothing happens. Earlier when I was using Xperia Z1. when I tried to play it in PC, i would get the message " this video is too large to be played. try to copy it to your library and play". But now I am unable to copy it. And get no message
Ravi17
Same here, only photos can be moved either manually or via mediaGo but I cannot move video files to system.
I do a manual work by removing sd card and the same is inserted in computer and then i copy, such a waste fo time.
Not user friendly
Emir1
Hero
That sounds very strange, I am sorry to hear that. Slightly_frowning_Face I tried replicating the behaviour just now, but it transfers just fine during my tests. Could you give me some more information about the video types? Is it video files which you have recorded yourself, or does it only occur to downloaded/transferred videos? In addition, just for reference, what computer system are you running (For example Windows 10)?
Jatin_zap
I can't view videos when Xperia Z connected to PC , I wang to transfer all videos to PC as they are using most of the space of my Mobile. They are all self recorded through phone and the format is mp4.
The path says storage /emulated/0/Dcim
But can't find anything as Emulated in PC
Please guide.
Roadrunny76
Enthusiast
When you connect your phone to PC are you changing the connection option from Charging only to MTP? When you browse your phone from the PC just check Internal storage (or phone) / DCIM.
