Preparing SD card, Checking for errors
Martin_Leow
I had this problem after I turned on the phone since last Wednesday.
Everytime I turn off and then turn on or restart the phone, the phone does not start. I have to press and hold both the volume up and power buttons for the vibration to start the phone.
I have put the card into my old M4 Aqua phone and I can access it. I have also put it in a USB adapter and I can access it using my computer. When I put it back into my XA1 phone, the "Preparing SD card, Checking for errors" notification apprears and I cannot access the card.
I have tried:
-error checking the card using the computer, but there was no error
-blowing into the SD card slot and cleaning the card
-formatting the card using the computer, and then again using the phone
-factory resetting the phone
-software repairing the phone
When after I did the formatting and restarted the phone, the "SD card for transferring photos and media" notification appears. I used the USB cable to connect it to the computer and put some pictures in it. After unplugging it from the computer, I could access the card and see the pictures. But after I restarted the phone, the same problem happens and I cannot access the card.
4 REPLIES 4
Uliwooly
@Martin_Leow
Could you test a different SD card with your phone?
Martin_Leow
I haven't got another SD card, but for now, as a temporary solution, I have put the contents in the internal storage of the phone.
Thanks for replying!
SD_2
I am facing the same issue after I changed my 32Gb sd card to a 64Gb sd card. Could it be the make of sd card that is causing the issue?
Bumba007
Yes I put 64gb in didn't work, swapped to scandisk card perfect change make and stick with scandisk m8
