Screen
Jorcan
Screen
Screen
Vertical stripes came out and the tactile does not work well or looks good.
Pantalla
Salieron rayas verticales y no funciona el táctil bien ni se ve bien.
Uliwooly
@Jorcan
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm sorry to hear about the issue, but try to take a screenshot
screenshot: Press and hold power & volume up for 1-2seconds at the same time
send that screenshot to a friend or transfer it to another device (computer, tablet, phone, etc) if you don't see the stripes then it is a hardware issue and you will have to send it in to get inspected/repaired >>> Local support
