Wifi connection issue
PsiAmNumber4
I am wondering if anyone can help me. My wifi on my xperia xa ultra keeps disconnecting and won't reconnect. Sometimes after I restart the device it will work fine for a while then when I leave and come back it won't reconnect. (I live on a college campus with campus wide wifi) other times the phone jut won't connect to the wifi. I know it's not the router itself because my computer connects to it just fine.
I really want to fix this issue without having to buy another unit.
29 REPLIES 29
CameronT
Champion
Hi @Miepje007,
Welcome to the community.
If it is functioning correctly in safe mode, then it would indicate that a third party app is causing the issue. Unfortunately, it's not easy to determine exactly what app is causing this to happen. The only real way to do this is to uninstall apps one by one until you find the one causing the issue.
Before you begin uninstalling apps, I recommend you make sure that all apps are up to date with the latest versions, as if an issue was present in the app, it may have been resolved with an update.
NealR
I have the same problem. The quickezt fix, as annoying as it is, is to turn off wifi and tben turn it on again. This usually sees the wifi signal and connects. This is a pain, but it is the only way short of restarting the phone.
Celica77Mustang
So, I bought XA Ultra like almost 2 month ago, I love it. It's an white model, and
But the problem is, It's keep scanning, it doesn't say it can't catch the wifi, nor no wifi is available. It just scans forever,  So I always have to restart the phone to connect the wifi.(It does connect to wifi) Which is really annoying, and I want to fix it immdiately.
Anybody have the same issue as I have? I've been searching google, but XA Ultra is fairly new, so I can't find that much info.
Here is device info, If anybody can help, I would appriciate it.
Uliwooly
Maybe repair the phone with XC
Xperia Companion (XC)
Software Repair Guide
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Didrik
Enthusiast
Hi @Celica77Mustang07,
I'm sorry to hear about the trouble you are having with your Xperia XA Ultra Slightly_frowning_Face
Is there any change if you reboot your phone to safe mode or is it still just scanning without finding anything?
I would also recommend performing a network settings reset, information on what data is reset when performing a network settings reset can be found here. In order to perform the reset, go to Settings > Backup & reset > Tap Network settings reset, the menus will look like the on the images below.
Check if you are able to find an available WiFi-network after the network reset.
Let me know how if goes!
Nyegnav
Same Issue for Me.
I also have Battery Drain as a result, and Bluetooth cuts out when listening to music.
I've read the XA had massive issues with these two things and were related to Location scanning. Apparently fixed in a software update.
I've noticed with Bluetooth and Wifi on the call quality also drops.
Seems like an issue with the radio.
If theres any solutions other than turning wifi and bluetooth off please let me know.
NealR
I had hoped that the recent software update would have fixed this annoying problem, but it's now actually worse.
When I move to a new wifi zone (work, optimum wifi, Starbucks, etc), my phone will not see the wifi, despite them being already registered on my phone.  On my wifi screen, it is completely blank, despite what I know are usualy multiple wifi souces in that area.  Prior to the software update, I could resolve this problem simply by turning off the phone's wifi, and then turning it back on.  It would then see and connect.  Since the software update, I now have to go through the process of restarting my phone for it to see and auto connect.  The same thing happens when I've been out and return home.  My wife and kids never have this issue with their phones.
It is not the wifi signal that's the problem, as I've done troubleshooting with other phones and they do not enounter any connections problems.  The problem is without doubt, the phone.
My phone is not rooted.
bob25678
  • Hello,
if this forum is place to SOLVING their bugs by developers rather than dilletetant clerk's advice then:
My router's wifi network to 3g and back again auto-switching doesnt work as in normal phones like mine samsung 2013 year of issue, which was capable to auto-switch between networks automatically (when enabled both functions in status bar) deppending of ip i was typing in chrome - for instance - 192.168.1.1 it switching to wifi network - www.google.com - it switching to 3g network. So what is wrong with these phone? I even setup autoconnect feature for ONE single wifi network, but device is constantly disconnecting of that wifi network when I start to use 3g internet and do never remmember to connect the same wifi network when I start to use wlan. It just stucking in "scunning" something (I already said that I setup wifi setting to autoconnect for single wifi network of the list). So what is the bug if wifi is stucking in lifetime "scanning" then? It probably wont reconnect to wifi as "No Internet Access Detected, won't automatically reconnect." Yes, on my home WLAN router "no internet access" as why I should have it there if my phone have the 3g internet? THIS IS THE BUG! Give it to fix to someone responsible for software on your side.
UPDATE: it wont reconnect 3g network from wifi wlan without completly switching wifi off too ???!!! Is that phone engeniered as a "system" or it is just some set of interindepended functions like separated wifi working in wifi mode only, with separated 3g working as 3g only untill you switch something off here, switch something else there? May somebody do wonder in your company , like "hey... but what is going to happen if user uses wifi and 3g enabled both" ....?
bob25678
the solution to my post above - does sony adopt a bit android to their phones users? Than these is what SONY's IT dept should do instead of numerous users themself on their side
> adb shell
> settings put global captive_portal_detection_enabled 0
may that written down solution be implemented on Nougat's OTA updates? Or I am speaking with myself in here? Helloo? Anybody there?
bob25678
Cuckoo? Will that anoying BUG be solved by some ROM adopters, SONY's "devs" on SONY's side or not? Google do not supports SONY devices ROMs - so start to DO YOUR JOB a bit!
