Hi AmolPrkPawar,
Welcome to the community,
I know this may sound to easy, but have you tried a simple restart to the device and any basic troubleshooting such as removing SD card and SIM for a short period of time.
@Jajo wrote:
good morning after upgrading to 5.1.1 ... I can not change the ring tone for each contact solutions?
I have the same problem, after the update there is the same ring tone for all of the contacts and I can't change it for anyone... 😞
Thanks, I'll try...hate to fill up my internal storage though...
i love using this xperia z, but after i got notificatin for upgrading i did updated my xperia z. i am expecting that my phone will be much good and nice but after i did upgrade 5.1..mt touch pad screen not working but have back light and still open but can touch? i did rebooting pressing power bottom and volume keys but always same problem? pls help me how i can fix it or how i can downgrade and back again to 5.0......
asap pls... notify me if u read my message thank you morepower xperia
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
okie i will try to do that... i hope it can help .. i will message u if ever its work or if i have question i hope its okie to ask u thanks....
