After getting update 5.1 Lollipop issue
AmolPrkPawar
After getting update 5.1 Lollipop I am facing issue when I am touching any contact for calling some times it doesn't work after waiting long time plz help
19 REPLIES 19
khali
hello its me again.. i did pccompanion already its the same a few days i can use normal my xperia Z if no attatch or if i remove the sd card only simcard i can use but every time i insirt sd card i cant use the touch scrren again..... then after pccompanion now both even with or without sd card or with or without simcard and sd card now tottlay hung ot stock up so i cant use my xperia Z now after i did ur proccess to update pccompanion...pls help me to fix this
profile.country.RO.title
_alexdon_
@khali Have you ever thought the microSD might be faulty?
alexdon
khali
hello sir.. as of now i try to re update again using the pc companion.. now i can use again normal even with sd card... i can use already the screen but sometimes hung again but just long press the power bottom and it will move again...thank you for ur advice... sir @alexdon >>>MORE POWER
_alexdon_
Sounds good.
alexdon
khali
ty
khali
wat the meaning of apprentis? what can i do being apprentis here? hehe
_alexdon_
Well, it is just a rank. But basically it means you can, slowly, help others to upgrade your rank.
alexdon
SanjayKavade
Hello Jake SonyXperiaSupport
After update 5.1.1 on my Xperia ZR C5502 I see one change about loacation setting. When I set location with battery saving mode. Then if I turn off this setting and again on it then the location setting mode changes to high accuracy automatically. This may causes to battery drain. I have checked this in safe mode too. This change was not in earlier 5.0.1 update.
Lolliop has many good features than Kitkat but where as if we compare to performance it is not up the mark of kitkat.
khali
what happened to my xperia z c6603 after 2 months my touch screen not working again i.did pc companion again but still almost 2weeks i.cant use my xperia z pls help meagain
khali
hello sir pls help me
