com.android.calendar error
i have situation of com.android.calendar error...
how can i solve problem???????
suze
Leader
I have seen this issue occur after an update, the solution that other users suggested was to go to Settings>Applications>Manage Applications then press Menu Button again and Filter>All. Then find Calendar and clear data/clear cache.  Have a look in the More Like This section to the right of the page and see if you can see any other information on the issue.
