Im sure this is a stupid question but please help,
I have downloaded Sony Ericsson PC Suite and it is all OK but should I be able to view my contacts list etc without the phone connected?. ie shouldnt the files be saved to the PC itself in a readable form?
If i search the PC (win7 64 bit) for my phone name the files found under that folder have extensions which windows cannot open.
Thanks for looking.
No, I'm afraid that with PC suite you cannot view your contacts without the phone being connected.You can back up your contacts as part of a back-up file and then restore them, but can't read them on the PC.You can however use the My phone Explorer (free) software which allows you to view the contacts without the need to connect the phone.
Thanks for your reply, that one is far more useful with just what I want. Seems odd that Sony produce a comprhensive suite without a save facility.
No worries.
