flash in camera
flash in camera
Hi everybody, I've a question in camera. In camera, I only see the photo light but it's not flash. so how can I change the flash function as like camera? Is it contain this function?
10 REPLIES 10
There is no flash function for this device as yet. It might come in a later update, but don't put too much hope in it.
you only turn on n off the light from the main and it will remain always on/off.
It was said that in AOS 2.1 onwards, it will allow you to use the flash light a normal camera. But how true is it i cannot confirm
suze
Leader
There is an app called Vignette that allows you to use the camera light more like a flash but it may not be available to you if you have no access to the android market.  Other than that it is a matter of waiting for the 2.1 update and hoping they have improved the settings for this.
Suze, correct me if I'm wrong, but there was no mention of this flashlight upgrade in the leaked roadmap, right? If that is so, we can only hope it is in that video upgrade.
Sorry, but I am currently not in the mood to get anyone's hope up for nothing, especially after that end-September fiasco SE made.
Why can't we use the android market???????????? That's xo bad!!!!!!!!!!   Everything is in the android market and the other site of the android applications give the trial version and most of them are with charges.. Slightly_frowning_Face  bYaL!!! I want to go foreign country. I dun wana live here.............
sushidushi
Yes, that is unfortunate.  The phone is certyainly far better when one has access to the Market.
sorry to hear that.
But you can always try other sites with full ad-supported apps...
I'll give you a few to begin with, hope it elevates some of your Market-pain.
www.getjar.com
www.appbrain.com
www.androidzoom.com
These sites should cover most if not all of what Market has.
darkmax@ Thank you guy! I already use this websites. do u have another websites?
nope that's all I use.
