hi can anyone help me? heres the pictures.. hope you could help me..
when it hides i reboot my phone.. then after a minute.. it hides again.. i cant access my notification bar..
sorry again for the bad quality.. i used my nokia e71 to capture this.. and it has a mirror screen thats why..
s
ANYONE?
Not enough detail.
Hopefully a REPAIR using SEUS will help.
You could use a different home launcher, ADW.Launcher for expample. This is much more customisable than the stock launcher and should overide the problem if the repair doesn't work. I also use an app called Home Switcher that lets you choose which launcher you want, either Home which is the SE version or ADW and then you can choose to set it as default.
