How can I hide old repeating Calendar entries?
I attend a large number of   meetings which occur on a fixed day of the month every year rather than on a chosen  numeric date, e.g. the Second Wednesday in December, the Fourth Monday  in March etc.
After each meeting is completed I delete the event instance from the Google calendar using a PC-based  web browser. I do this because I have  noticed in the past and also with the 2.1 version that changes made to  repeating events in Calendar do not get properly synced to the Google  server version of the data, whereas changes made to them on the server  are updated correctly in Calendar.
Since updating to 2.1 and re-syncing all my Contacts and Calendar with Google, I now find that on the phone repeating events in the Calendar extend  years backwards into the past as well as forward into the future.
By  that I mean that old meeting entries that I deleted months and years  ago on the web, and which were not visible on the phone before the  update to 2.1, have now all re-appeared on the handset and go back  quite a few years.
I quite like the way that the Agenda view is now continuous and you can scroll forwards and backwards over month boundaries when you had to switch to Month view to do that previously, but I now often find that the Agenda view has slipped back a couple of months into the past for  no apparent reason.
Does   anyone else experience the same behaviour, and is there a simple way  to  fix it - i.e. to hide past instances of repeating events? I can't   delete them on the web, because they are not visible there, and I can't  delete them on the handset, because they don't get synced properly.
antient
Dont think you can in stock calendar app its all events or one event in the series no historic clean of past events, you could try a free app from teh market
such as this one see if there are any availalbe that do that
http://www.appbrain.com/app/business-calendar-beta/netgenius.bizcal
