Help Needed with a ERROR Message
I updated to 2.1, after the update it was working fine, but all of a sudden when i switch on my x10 mini i get a error message.
Can anyone provide me a solution for this?
Here is the error Message:
The application SEMCCheckin (process.com.sonyericsson.semcheckin) has stopped unexpectedly. Please try again.
Aimee
Enthusiast
I'm sorry to hear of the problems you are experiencing. Have you tried reinstalling the software using the Update Service program at all? You can download this here:
www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10mini
Let me know how you get on.
Having the same problem at my x10i. if i get this error, sim-card/sd-card wont be available, cant be used as usb device, wifi cant be enabled... i cannot do anything... reinstalling the software fails because my x10 is not found by pc companion/update service... with every restart i have to setup the phone once again
Problem fixed. i had to install the driver for the flash device manually...
