Install modem on winxp for sony xperia min pro
hi this is vinay.My question is how do I install modem for xperia mini pro on windows xp.
Please sugest.
suze
Leader
Hello there, if I understand your question correctly and you want to use your mini pro as a modem for your PC then you will need to download an app from the Android Market. I personally use PDAnet but have also heard very good things about EasyTether, they both have a free trial so you can see if it works for you and then you have to buy the authorisation key which I believe was around £10 for life.
