I have a new x10 mini/pro and I cant find the link on my phone to "Install PC Companion". I would appreciate some help here, even if I am missing the bleeding obvious. Thanks.
When you connect your phone to USB do you not get three options? One of them is install pc companion if not you can download the application alternatively here http://www.sonyericsson.com/cws/download/1/786/189/1288082474/Sony_Ericsson_PCCompanion_2.01.058.exe
I've found the link better to use.
All good. I recharged and connected the phone again to the computer and it worked. Maybe the screen options did not appear the first time because the battery was pretty low. Muchos Gracias!
