Hello, can I ask you for a help? I have problems with lack of memory on my Sony Xperia E and when I use clean master app the program shows me that I can delete some big files with .hprof extension. What will happen if I delete those files. The use all of my memory 1,89GB. Best regards
You should be able to delete those because as far as I know,those are dump files related to memory or applications,something like that.But you should not use clean master.
How am I going to delete those files, connecting to computer then deleting?
You can delete using the clean master,I just not recommend people to use task killers or cleaners in general.
I've done it with Clean master and I have no problems now. Thanks for help
Ok,good.
