Missing options after camera update
Thomas_87
Updated this morning to camera v2.
Now there are all the second pages from the menus missing.
If i click on "more" nothing shows up.
So i am unable to get to Image stabilisation or grid.
I cleared the data and cache but its still not working.
23 REPLIES 23
Hampus
Champion
Are you using the camera in landscape mode or portrait mode? When you are in landscape mode, does the arrow next to "More" disappear? If yes, you should be able to scroll down to find further options.
Thomas_87
I use the camera in both modes.
If i click more, i am able to scroll, but nothing more appears.
onkkel
I have this exact same problem. I get the "More" button but after pressing it nothing comes up. After some further investigation it seems that the additional settings are there but aren't visible. If I scroll all the way down and press in the "empty" space I get a prompt about activating touch block.
Hampus
Champion
Which phone models are you guys using and also, which build number does the phone have (Settings > About phone > Build number)? Which language is being used in the phone? If you have changed the Theme in the phone, could you try a pre-installed Theme?
onkkel
Phone model: Xperia Z5
Build number: 32.0.A.6.152
Language: Finnish
Theme: Pre-installed dark theme
Changing the language to English (I've tried United Kingdom and Canada) doesn't make a difference.
Here's a video showing the problem:
https://www.dropbox.com/s/mz2oeuqdlv71a0g/2015-11-16%2015.15.03.mp4?dl=0
profile.country.AT.title
skycamefalling
It's working fine for me, all the options are there and visible.
Z5 compact, CE1, 32.0.A.6.152, German language
Hampus
Champion
I will forward this internally to see if I can get some further information.
onkkel
I got the advice from another forum that enabling the animations in developer options corrects this problem. I had removed the animations and after putting them back on the problem seems to have dissapeared.
Hampus
Champion
I will forward this as well. I do not recommend that you change any developer options since they are intended for app developers. The options are not intended to be used for general usage.
