Missing options after camera update
Thomas_87
Updated this morning to camera v2.
Now there are all the second pages from the menus missing.
If i click on "more" nothing shows up.
So i am unable to get to Image stabilisation or grid.
I cleared the data and cache but its still not working.
23 REPLIES 23
Dadray
Uninstall the update that will fix but you have to rest your settings back to how u like it its the only fix I know off at this time hope it helps. In apps u will find camra and uninstall the update
Tamman
Hello everyone, I just bought z5 compact, update everything, restart but it looks like camera settings are invisible. I can randomly press different options and set it up but it's really annoying.
Anyone got same problem or solution?
Tamman
Here is the link for video where you can see what is going on.
https://youtu.be/2tnnpiBurv0
Tamman
Turning back animations in developers setting resolve the issue, thanks anyway
