Music won't synchronise from my laptop to my Xperia z
Joshridd14
Every time I try to transfer music to my phone it starts synchronising then freezes and only a few songs will be transferred. I have tried deleting all the music on my phone and I have done a factory reset on the phone too however it still won't work. Also I have tried using other laptops and computers but the music still won't synchronise I never had a problem before so was wondering if I might have a bug or something similar Any help would be much appreciated as this is getting frustrating.
11 REPLIES 11
Uliwooly
@Joshridd14
How are you transferring the music?
Joshridd14
On Windows media player or just by dragging and dropping straight from the files never had a problem before. now it won't synchronise any music at all and I've tried deleting the music apps and re-installing them
Christofer
Champion
Hi @Joshridd14,
Do you sync the music the your phone's internal storage or do you have a memory card that you sync to?
Joshridd14
I have tried both I had a sd card but removed it thinking it might be because the sd card was corrupt however it doesn't sync to my phone internal memory either even though I have 8gb free memory.
Joshridd14
Also photos and videos will still sync perfectly fine literally just music that won't.
Christofer
Champion
Are these normal .mp3-files or do you use another format for your music?
Joshridd14
They are normal mp3 files.
Christofer
Champion
Try clearing data for the Media Storage app, Settings > Apps > All > Media Storage > Clear data, and restart your device. Then try to transfer som music files to your phone again.
Let me know if it works. Slightly_smiling_Face
Joshridd14
Thankyou for the suggestions christofer I tried what you recommended but sadly still no luck I'm rather baffled to be honest.
