I got my x10 mini pro today but cannot get my phone to work with my home network. It's says it's connected but when I try to use the browser,facebook etc it won't load pages (these are only working through mobile internet). Does anyone know how I can fix this?
it might be the type of password
I've seen on other forums that some Android phones don't like symbols in the router password, is that what you mean?. This is not the problem here though...
Please access the following link to see more about internet connections and the steps take: http://www.sonyericsson.com/cws/support/phones/detailed/internetconnectionts/xperiax8?cc=gb&lc=en&se...
I changed my wifi router recently and am using the default (or randomly-generated) user name and passwords. With mine, there is the name of the network (let's called it sushidushi) as well as the name with 'guest' after it. To be honest, I am not sure why the guest account appears, but I have fiddled with it in response to your query and notice that I can't download anything on the phone connected to 'sushidushi-guest', but the one connected to plain sushidushi is fully functional. Could it be something similar with yours...?
Try removing the dash (-), replace with an underscore (_)????
In my particular case, the phone searched for available networks, so I didn't have to type the name in, but changing to the non-guest version solved the problem. I just thought gthat the original poster might be running in to the same issue. I find wifi routers can be a pain. I bought one about nine months ago and it would never quite work properly. I had to reset it almost every time I wanted to connect the laptop or phone to it. Occasionally it would be fine, and at other times, it would throw me out very few minutes. It might just have been a setting, but I tried all sorts of things and nothing would work. In the end, I just bought another router, and that is working beautifully (now that I know not to use the guest account!).
My router only has the "name" not "name-guest" so that's not the problem.
I've downloaded a Wi-Fi Manager App and that's saying I'm connected and have full signal strength...
What IP address is the phone given by the router?
Check that under.
Menu > Settings > Wireless and networks > Wi-Fi settings > Click on the network that you are connected to and check that you've got a valid IP address for Internet access.
192.168.1.3
