Problem with browsing using wi-fi
I got my x10 mini pro today but cannot get my phone to work with my home network.  It's says it's connected but when I try to use the browser,facebook etc it won't load pages (these are only working through mobile internet).  Does anyone know how I can fix this?
13 REPLIES 13
Hi, here's the same problem with my satio. And just now I've found solution, maybe it works on your x10 too. Finally solved it by accessing advanced settings once connected to my network > disabling automatic configuration and then disabling Power Saving. Please note the part ONCE CONNECTED TO MY NETWORK, so prior to proceeding with other advanced settings make sure that you are connected to your wi-fi network (even though you get the "no gateway" message if you try browsing). Please tell me if it works for you. good luck Slightly_smiling_Face
I can't find these settings on my phone... Thinking_Face
Johan
Master
There are no power saving settings for Wi-Fi on X10. I suggest you check your router settings. Make sure that your phone is not blocked by any MAC filter.
Because it seems to me that it might be blocked by a MAC filter or similar.
gwhispererz
Champion
Just to confirm whether it is a phone or router issue, try connecting to another Wi-Fi network.
