Problem with updating
Hoangnam2
Can you show me how to update my Xperia M4 to 6.0 by Xperia Companion? I tried to follow the steps on the app but nothing happened after all. Thank you
4 REPLIES 4
profile.country.PH.title
MarlonUk1
do you encounter error when upgrading?
if it says the you still have the latest update then you have to wait until the update is released on your area.
make sure you are using the usb cable that is bought with your device, try to use different ports on your PC,
try to reinstall the Xperia Companion.
Hoangnam2
Thank you
MarlonUk1
no problem,
were you able to upgrade? you can check here to know if the update has been released for your phone: Xpericheck.com
Sombit
I was also facing the same issue initially but after repairing the Xperia Companion it started the update process. But yes need to check if its available or released in your location 🙂
