Problems AFTER KITKAT UPDATE
LOVELESHKHATTER
HI
I UPDATED MY XPERIA T2 ULTRA DUAL (D5322)
WITH LATEST FIRMWARE HAVING ANDROID 4.4.2 AND BUILD VERSION 19.1.C.0.116
AND AFTER THIS UPDATE I AM FACING MANY PROBLEM
ONE OF THE MAJOR PROBLEM IS THAT NOW WHEN I CONNECT TO XPERIA WITH FACEBOOK IT CONNECT PROPERLY BUT IT AUTOMATICALLY DISCONNECT AFTER SOME HOURS
I ALSO TRY TO REPAIR MY MOBILE USING PCC
AND FACTORY RESET OF MY PHONE
ALSO CLEAR DATA AND CACHE OF XPERIA WITH FACEBOOK AND RETRY THE WHOLE PROCESS BUT THE PROBLEM IS STILL THERE
AND THE OTHER PROBLEM IS THE ICON OF APP ON HOMESCREEN IS NO LONGER AVAILABLE AFTER RESTART OF APPS STORED IN SD CARD
AND ALSO IN NOT MOVES THE APP TO SD CARD IT MOVES THE APPS TO INTERNAL STORAGE
AND THE OTHER PROBLEM IS THAT I AM NO LONGER ABLE TO USED MY SD CARD WITH ANY FILE MANAGER
NO FILE WILL BE COPY, MOVED INTO SD CARD
AND DELETE AND RENAME OF ANY FILE STORED IN SD CARD IS ALSO NOT SUCCESS
SO PLEASE SOLVE MY PROBLEM SPECIALLY XPERIA WITH FACEBOOK ACCOUNT PROBLEM
Xperia_Fan123
Hi Guys, Even i am facing the same issue after the 4.4.2 update Rather is again asking me to update the System Software
