Re: Battery problem
Ajay3344
Re: Battery problem
Don't show battery percentage real. When my mobile is 50% than switched off.
And when i charging my mobile than after 1 minte show battery percentage 40%
13 REPLIES 13
Hampus
Champion
Does the phone power off at 50% and you are unable to power it on agian? When the phone won't power on, could you remove the battery and insert it again > Without trying to power on the phone, connect it to the charger and let it charge to 100%.
Ajay3344
Ok i will try it
Ajay3344
I tried 4-5 days continue
But no solution
Hampus
Champion
I suggest that you perform a software repair via PC Companion. This will reinstall the latest available software for your phone.
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
Follow the instruction that appears in the program and do not connect your device until this guide tells you how to connect it.
Note that, this will erase your pesonal data. Don't forget to backup your data before this repair, but I would also suggest that you use the phone for a while without restoring any backup to exclude problems related to your data.
Ajay3344
I tried also trick but no solution
Ajay3344
And tell me next suggestion
Hampus
Champion
Unfortunately, it sounds like your phone needs to be examined by a technician at an authorized service center. I suggest that you contact your Local support for information about nearest service center and/or how to proceed with this in the best possible way.
Ajay3344
how to purchase a new battery
Hampus
Champion
A battery can in some cases be purchased from a local retailer. Recommend that you check with local stores near you to see if they have any in stock. Xperia M/M dual uses the BA900 battery.
