Ringtone bar?
Ringtone bar?
Does anyone know how to get that bar with the wifi, sync, brightness, etc onto the homescreen after the new 2.1 update? I accidentally deleted it and now i cant find where to replace it. Also, how do you change from ringtone to vibrate or silent mode? There use to be a quick setup icon on that bar i was talking about before, but now that's gone too?
Long press on the screen where you want it, tap widgets and find Power Control that's the one you want
suze
Leader
Plus 1 on the previous answer.. took me a moment or so to find it as they had changed the name!
Also on the ringtone, just use the side keys for ease as you are correct in that this has been removed from the Power Control widget. It gives you vibrate or silent at the bottom end of the volume scale.
