Sending SMS not working anymore after update to Marshmallow
don_carlos
Updated yesterday my Z5 compact to Android 6.0 and can't send SMS anymore.
Anyone having the same problem?
13 REPLIES 13
Uliwooly
@don_carlos
Do you get an error?
settings > more > mobile networks > do you see your network?
don_carlos
Yes, I get  "Could not send"
and also yes, I see my network.
I can receive SMS but not send. My carrier (Swisscom is also checking if this is a Marshmallow 6.0 update issue).
Uliwooly
@don_carlos
Could you test it on >>> safe mode
CameronT
Champion
Hi @don_carlos,
Welcome to the community.
Try resetting the messaging app too, in Settings > Apps > Messaging > Storage > Clear Data > Back > Force Stop. Then restart your phone.
don_carlos
I did the reset of the messaging app but it's still the same. Cannot SEND SMS !!  😞
Always get error "Could not send" .
@CameronT   any other suggestion?
CameronT
Champion
@don_carlos,
Check with your network provider if your SMS Service Centre Number is correct.
don_carlos
This we did yesterday already. It's correct.
I can receive SMS but NOT SEND.
richtrabing
I have similar problems as described in this thread. I have a Sony Xperia Z3 Dual (D6633, v.6.0.1, Build Number 23.5.A.0.57) and am using Simyo and Telekom as providers. Everyting worked perfectly with SMS sending/receiving on the previous version - sorry, don't have the verson number.
Since the update, I have only just also noticed that I am no longer able to receive SMS through the Simyo provider.
I have tried the following to resolve the issue (as described by this thread)
  • restarting in safe mode
  • setting/updating the SMSC number manually
  • deleting the Messaging settings and cache
Trying "settings > more > mobile networks >" shows the network normally for Telekom, but not for Simyo. When searching for Service Providers, it only shows "Netz". I think in the past it actually showed "Simyo".
Do you have any suggestions on how to deal with this? Thanks in advance...
CameronT
Champion
Hi @richtrabing,
Are you and @don_carlos able to try another SMS app and see if the issue persists? There's plenty available free on the Google Play Store. I want to test if the app itself is the problem or something deeper with the core software of the phone.
