SMS counting
SMS counting
in Android 1.6, you could see how many messages you had with a certrain person. for example, me and my friend had over 200 text messages between eachother.
after the update to 2.1 this is gone, and i would like that back, is there any way?
I tried too look for a replacement program in the market, or at the configuration, but i couldnt find anything.... any tips?
suze
Leader
I use Handcent SMS and this gives you the figure in brackets on each thread... just looked at my phone - gosh I text a lot!
thanks, thats exactly what i ment, just 1 problem... I sent over 400 texts to some1 with a long name...  so it disappears, it only says (41..)  now instead of the full number, and i cant seem to get it right
never mind, i found it, thanks a lot :smileygrin:
