Sony M5 front camera needs full functionality
usman-101
As M5 front camera is 13 pixel, it should behave like complete camera. Also lcd bright function should be available as flash for night selfies. I can achieve these facilities by using Mx camera but i need through Sony software groups. I'll wait for reply because every good company respect their customers' feelings.
16 REPLIES 16
Uliwooly
@usman-101
This is a user based forum, you can send your feedback to Sony directly >>> Local support
On a side note, take advantage of a smartphone and check the playstore, they will have an app or multiple apps to customize your phone as you please, you no longer have to wait for a OEM to release an update to add features, in other words you have a smartphone not a feature phone.
icstm
@usman-101
When you use Camera MX does the camera focus as fast as when using the Sony s/w? When I use Fv-5 it is slower, so I guess it only uses contrast dectection.
Would you be so kind as to post some results from your camera, especially from some objects over 1m away from the front camera and over 10-20m away for the rear camera.
What would be ideal is if you also take some with some objects in the forground but with the focus on the objects further away.
icstm
@uliwooly, who do I @ mention someone?
Uliwooly
@icstm
if you are using a computer add the link to their name or if you are on a phone scroll to the bottom > Full (version)
usman-101
Mx camera is a bit slower, also it take much battery due to increasing screen light.
usman-101
Personally i found this phone good in camera quality. It will be more good, if Sony takes some steps. In my friends, everyone believe in Sony camera's quality now.
icstm
@uliwooly I do not follow do I paste this?
/t5/user/viewprofilepage/user-id/202
icstm
Nope that did not work
icstm
@usman-101
As I said I too was hoping for a great camera, but mine has problems. I would love to see your results. If you are not comfortable shaing publicly, please PM me.
BTW, I too have FV-5 increase the brightness! Makes it easier to get a sense of Exposure.
