Sony M5 front camera needs full functionality
usman-101
As M5 front camera is 13 pixel, it should behave like complete camera. Also lcd bright function should be available as flash for night selfies. I can achieve these facilities by using Mx camera but i need through Sony software groups. I'll wait for reply because every good company respect their customers' feelings.
16 REPLIES 16
Uliwooly
@usman-101
If this feature it's implemented to the M5 front facing camera, it will drain your battery similar to third party apps. Perhaps the Xperia C3, C4 and C5 are better alternatives since they have front facing flash.
But with that said, do send your suggestions to Sony.
Uliwooly
icstm
I'm sure uliwooly will tell us the best way to post pictures.
If I understood how to @ him I would give him a nudge...
In the full editor on desktop/full site version - there is a "Insert picture" button with the classic landscape icon.
Uliwooly
@icstm
There isn't a way to add a picture on the mobile version, why? I've asked this question before, the reason is that the mobile version has to be as fast and direct as possible.
So what now? either enter full version, but that will require to wait for a moderator to approve the picture.
ok so what do you suggest? upload the picture(s) to dropbox, box, drive, etc and post the link here.
usman-101
@uliwooly i think having front camera without functions is alsoof no use. Atleast some filters shokud be present. I used some downloaded applications inside camera, but by using long battery mode, they don't appear
usman-101
I already talk with American agents, as i may have problem to explain same things in Turkish. But he referred me to this website. Thanx to you all, its my first time with sony.
Uliwooly
@usman-101
That's normal that certain features won't be present if you are using stamina mode, those other downloadable cameras and AR drain quite a bit of battery.
