Run Xperia Diagnostics, test the screen and display
Boot to safe mode, does the problem still occur?
if yes, then it might be a hardware problem, try to remove any screen protectors that you might have installed, and or visit your local service center to have the display checked
if no, then it is most likely a software problem , try to perform software repair using Xperia Companion
