Touch screen not responding sometimes.
jaybowski
it happen during unlocking of patten when screen is locked. the line keep cut off when my finger slide through the pattern. is it normal?
8 REPLIES 8
Uliwooly
That's normal but do elaborate
jaybowski
When dragging to form a line through pattern. The line keep cut out itself when I dont even lift my arm yet. Not only pattern, dragging the volume up and down sometimes stop in the middle of the sliding
Uliwooly
Test your touchscreen
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
Do you have an additional screen protecting film?
jaybowski
Have tested and it fail to made a number 8. Yeah I have an additional screen protecting film
Uliwooly
Remove it and try again
Mystic
i think this is really about using a cheap screen protector or using one thats made of a non charge conducting material. Some screen protectors are so think that they stop the touch on any screen.. try to get a good one. I personally opted for a matt finish because i know it helps send the touch sensitivity through well.
brapi2
Hi, Matte finish usually is thicker, and reduces the contrast of the screen. Much like it blurs since it's anti fingerprint. Have you also have the same problem before using a Matte finish screen guard? If yes and the problem is gone then it's worth trying. This could help a lot of people having the problem including myself.
