Update Problem
Update Problem
Hello.I try to update my phone from 1.6 to 2.1 with the SEupdate program and it failed.Now my phone won't boot up and it only shows a picture with a phone laying down and an a exclamation mark inside a triangle. Any advise?
Thanks.
4 REPLIES 4
KrazyD
Hello, try and reinstall the update using Sony Ericsson Update Service.
Hi. Thanks for the reply.
I try 3 times and nothing happens.
KrazyD
So when you connect the phone nothing happens? If you are still failing with the update I would suggest to take the phone to a service centre.
I will take where i bought my phone.
Thanks again.
