Is this only related to videos that you have downloaded or from streaming functions such as YouTube? Do you experience this behaviour for videos that you have recorded with the camera function?
How do you mean by downloaded videos? Have you moved them from a PC to your internal storage/SD-card? Could you record a video with the camera function and play it to see if same behaviour appear when mobile data is ON?
Since a recorded video works fine, it does not sound like an issue with your phone. It can either be your connection (while streaming), have you tried different network connections, for example a Wi-Fi connection? Regarding the downloaded videos, it may be the format of the video that is causing this behaviour. Have you tried different apps for video playback such as MX Player or VLC?
I have the same issue on my new z3+. i use the same micro sd card that i was using on my previous phone (a Sony SP) which holds video files plus i stream youtube videos and am using the standard video player and mx player. the issue is the same: the video sporadically stops playing during playback but the audio continues
I had not realised there was a link with mobile data being on but if that is the case it does seem to be a major flaw.
is there a fix coming or work around other than not having the mobile data on?
