w100i spiro
triblekill
w100i spiro
How to reset seetings to default from w100i spiro ?
7 REPLIES 7
triblekill
Me need to service code to reseting
Dr_Chris
Champion
Have you tried using a default security code such as 000000 or 123456?
triblekill
Yes me forgot my phone code, programm Sony PC Companion  no recovered settings default, me need reset settings to default and to my phone clock reseting from '0000' (sory my bad english)
Dr_Chris
Champion
Hi, if you have forgotten your phone lock code, then you need to take it to a service centre to have the phone unlocked and reset back to the default code.
triblekill
service centre is paid !!
I just need to reset the default settings service code or data-cable !
Pc companion not dropped code to default possible have else (Free) soft ?
Dr_Chris
Champion
The whole point of having  a phone lock code is so that nobody else can use the phone, so PC companion cannot remove the code that you have forgotten. I suggest you contact the service centre so that they can arrange to unlock your phone.
triblekill
service center is very expensive and time because there is a service code resets the default
