Xperia S network problem
FolkCleric
When I've bought my Xperia S, I've noticed, that sometimes my phone signal is gone. First I thought, that it's network provider's problem, but after a while, I've noticed, that my parents and sister (they are using the same network provider) don't have that problem. The signal comes back only when I restart my phone. It really annoys me, because I can't get any messages or calls ant it drains my battery faster.
I've tried to reinstall my phohe using PCC, but it didn't solve the problem.
Phone info.
25 REPLIES 25
FolkCleric
Any suggestions? This morning it happened again..
FolkCleric
Anyone? I thought flagship devices had better support. Slightly_frowning_Face My bad. Neutral_Face
Smailchenko
well i'm not an expert but i'll tell you my suggestions
1- Do a factory reset
2- Repair using Sony update service not Pc Companion
3- Do another factory reset
if that didn't help try to use a new simcard
FolkCleric
1. Didn't help
2. Already tried.
3. It happens with any simcard.
Thanks for suggestions. Slightly_smiling_Face
FolkCleric
Well, I guess I'll have to wait for the Jelly Bean update and hope, that it will fix this problem. Slightly_frowning_Face
Johan
Master
I suggest that you have your phone examined and fixed at an repair center if this happens using any SIM card. Contact your local support team for more info.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
FolkCleric
So, finally I have received Jelly Bean update and guess what I have found this morning. No Service. Slightly_frowning_Face
Had to reboot my phone again. My SIM is new and signal on other phones is great.
Android version: 4.1.2 Jelly Bean
Build number: 6.2.B.0.200
liakoulee
Ever since I updated to Jelly bean, the phone loses signal, it's like the antenna stops working all of a sudden. Doesn't seem to be a hardware issue as it didn't occur while the phone was on ICS...
shlain66
That is not encouraging news. The only reason I wanted JB was to fix the periodic loss of network.
