It comes up a text: Read error. Try again. at my mobile's screen a few seconds, then it disappears but shows up very often and I do not know what the problem is I dont have any aps that are on.
Dont know if Read erros. Try again. is the right text on english but in swedish it says: Läsfel. Försök igen. If that gonna help?
My xperia Z ultra also encountered this problem. But upon removing the sd card and putting back the problem is gone.
Hi, I have exact the same error on my German Xperia Z, where the message reads 'Lesefehler. Versuchen Sie es erneut'.
This is already discussed on the German androitpit.de but no solution so far.The problem seems to go back to the update from Android 4.1 to 4.2 but did not go away with the 4.2.2 update. It occurs only when the phone has data connection. Also a factory reset does not help.
By the way: the problem has nothing to do with a SD card since I am currently not using a SD card.
Thanks lz, this solved the problem!
