I have the xperia z for a while now it is a awesome phone
but after a few week ago I bought a bumper for it and it look awesome but the power button is hard to press with the bumper on
so I search on the google play store for an app that wake up the phone using sensor or like the iphone touch thing
the apps are called Awesome On Off - Smart Screen and toucher..
when I press lockscreen button / using the sensor for the app it locks then turn back on
so is it a glitch on the phone itself or just the apps are not supported for the xperia z?
Please Help..
Thanks In Advance.. : )
If the sensor works fine when on a call (please feel free to test this if you’re not sure) then it is more likely the app itself.
What are your thoughts about this forum? Let us know by doing this short survey.
It works fine.. thanks
So the apps are not optimized for the xperia z yet then?
