Battery Drain fast
Jhero
Battery Drain fast
I lost 25 to 30% without using my xperia XZ in just 4 hours with the latest update 41.3.a.2.157. No running application , gps is off , bluetooth is off, nfc is off, wifi is off (having a hard time to connect to wifi ,also) ,
Bad update. I already uninstall AVG , MOVIE CREATOR, etc. Unnecessary apps.
Uliwooly
@Jhero
Provide the following screenshots
follow the steps
Charge the phone 100%
use it as you normally would
once the battery has reached 10%
Settings
Battery
take a screenshot of this
Menu
Consuming apps
Show all consuming apps
take screenshots of the list
tap on the top 5 items/apps on the list and take screenshots of each
post them all here
Jhero
Just what i posted.
No running applications Slightly_frowning_Face
It is phone idle
I think its not usual 25% without touching my phone.
And take note i already did factory reset . Theres no 3rd party installed. And unistall movie creator and disable all app that i dont think i can use.
Anyway thanks
I hope sony will do something
