Bluetooth codec stuck on SBC
sgiesen78
 First of all, kudos to Sony for the XZ3. For the world's best OLED screen and the most beautiful Sony phone yet.
My Bluetooth codec is stuck on SBC. I am using the in-ear Sony WF-1000X. AAC not possible. No matter what I try (tried to turn on Priority on Sound Quality in the Headphones Connect App).
I am coming from the Sony Xperia XZ and there it worked ....
Android 9 Problem? Anybody in here who has fixed this or connected by using LADAC or AAC ???
32 REPLIES 32
gregorg1
Today i got a new Update for my XZ3.
I hoped that it fixes the headset quality  problem, but still XZ3 uses only a lowband SBC while using for a call with my Sennheiser Presence.
The headset works fine with my Samsung S8. So it can´t be a failure of Sennheiser.
Kind Regards
Alex161
Hey, I'm not sure if you're still having this issue but I noticed that the Headphones Connect app has an option to select better Sound Quality which will change the code from SBC to AAC
John_C1
Reset the headphones to factory settings. I had the problem with Bluetooth connection stuck in SBC mode. Factory reset cleared it! Good luck
