Certain apps won't work on my home wifi
JohnB440
Hi all, as the title says certain apps on my phone cannot connect to the internet properly. Netflix wont load, Amazon wont log in, eBay wont log in, Snapchat wont send pictures although it will receive them. I can use google play and browse the web though. This is ONLY an issue on my home router. If I’m using mobile data or any other wifi network I have no issues.
I have done the following to try to resolve the issue;
Restarted phone, uninstalled affected apps and reinstalled them, cleared all relevant caches on phone, restarted router, reset router, disabled IPv6 on my broadband, tried disablingIPv4 also and I also did a factory reset of my router. Replaced the router, changed to google DNS, tried multiple DNS actually, changed MTU from 1500 to 1498(someone on an android forum suggested that)
None of these things helped.
I thought it was an android issue but my brothers phone which is also android 9 works fine.
My phone is an XZ3 on android 9. My home broadband is just regular not fibre broadband. I get about 4 mb.
Anyone else have this issue? Any advice at all?
HELLO SONY YOU THERE?
0 REPLIES 0
