Wi-Fi connectivity
Banex
Wi-Fi connectivity
When I turn on the Wi-Fi it will not connect at all to known networks unless I pull down press and hold the Wi-Fi button to open the Wi-Fi settings, it's really annoying. Also it's super embarrassing that my xz premium has worse connectivity than my m4 aqua, which can connect a Wi-Fi network from places my xz premium can't even pick up the signal. How do I make the wifi on my phone.
mahesh911
@Banex wrote:
When I turn on the Wi-Fi it will not connect at all to known networks unless I pull down press and hold the Wi-Fi button to open the Wi-Fi settings, it's really annoying. Also it's super embarrassing that my xz premium has worse connectivity than my m4 aqua, which can connect a Wi-Fi network from places my xz premium can't even pick up the signal. How do I make the wifi on my phone not **bleep**
This issue is kind of appearing in both xz premium and XZ1..  For the time being the solution is to restart your phone. To avoid the issue repeating , need to restart or WiFi modem and also setting WiFi signal to 802.11n might help minimise occuring of issue too many times..
If in public WiFi area, the only thing to do is restart your phone.. and yes it's annoying ..but unfortunately there is no other fix. Sometimes it appears fine with a different modem or router but the exact cause of this issue I guess is unknown and not sure it's software or hardware problem ..
