Are XZ1 owners facing any software or Headwear issues on your XZ1????
Solved! Go to Solution.
hello. my xz1 's screen is too Sensitive . any sometime ui fps drop. chrome scroll web lags. asphalt 8 low setting drop fps. how can i fix it?
My XZ1 has always had a phone idle draining my battery ever since I've had it and it barely lasts a day with even doing anything on it and uses about 25% of my battery alone and 602 mAh which means I'm always having to charge it early and then I can't run it back down to charge it at a decent time ready for the next day and the battery care doesn't kick in due to the different times I charge it
Smartwatch SWR30 dosn´t work with Android 9. All numers from contacts are signed as "Unknown".
Music Player don´t know the new picture from the new music files, when i have delete the old version.
My brand new xz1 keeps on crashing (UI) problem when i get incoming/out going calls. There is no sound coming out from the phone as well and its not letting any videos play (whats app, facebook, youtube). Do have any solutions
Whilst it's new out of the box, check for updates, new Oreo, and software repairs should arrive between 18 - 48 hours from phone start.. It's usually evening if we started the phone in the morning.
While the phone is new, it's good to factory reset all updated apps to make them work properly...
Video player, google store, album, youtube app... Go for Aplications > Clear cache > clear data > Restart the phone > launch the app again and log-in like for first time.
You can clear data on multiple applications and then restart, don't need to restart the phone on every single app 😛
