Google Smart Lock does not work.
MadbooM
I have rebooted myself when I connected xz2c to my PC.
Google Smart Lock does not work after that.
There is nothing on the Smart Lock settings screen.
11 REPLIES 11
Midtown999
Temporary fix .Trusted sites will disappear again after a few hours. At least they do on my xz2 compact that is less than 6 months old
cerb114
sorry for my english
I share my experience.
In my case it was an app related problem. I had same trouble with smart lock as you mentioned. I sow that an application crashed every reboot.
As I removed the app I sow no more smart lock stop!
the app was quik (gopro).
So I think you can look for app that in any way interfering with smart lock (or trusted agents), remove it and try.
greeting
