I had a Z3 compact before and I was able to mark several messages to delete, why am I not able to do this on the XZ1 compact?
Has this feature been taken away?
Kind regards
Pebbles2
Works here.
From the main messaging window where it shows all the sms threads simply hold down on one of the messages for a couple of seconds until it selects it (a tick will replace the contact picture) - then select the other messages you want to delete - then tap the bin icon top right.
I would like to delete several messages not all messages within each contact. This was possible on the Z3 Compact.
