Quite simply: can it be done? Or is this a serious flaw with the xperia xz1 compact?
No, currently not.
Thanks... I will start incessantly moaning to Sony now!!
Cool, I would promote this...
@Robertsalan @TheRealEasy as far as I know, it's not possible to move apps to the SD card, most likely because of potential performance impact (apps on the SD card are slower to load).
Hello I cannot confirm performance issue when you take a high performance SD Card. Using apps on SD card worked very well on my Xperia Z3 compact
That's exactly what I've been writing before...
I am using a SDXC Class 10 U3 sd-card with, tested, speed up to 95 MB/s.
With a hardly slower one I did not recognize any loss in performance with the X Compact.
