How rename folder in oreo ?
Paysdoc
I've created a folder by deplacing icon on a another. So the folder is created with name "folder". How rename it to zzz.?
profile.country.RO.title
_alexdon_
Is your folder on the home screen? You need to tap on the folder name, upper side of the folder layout.
alexdon
4 REPLIES 4
_alexdon_
@Paysdoc tap on the folder itself then on the Folder name that you see. It will allow you to rename.
alexdon
Paysdoc
Thanks for the reply. When i tap on the folder, it open, and does not permit other action.
_alexdon_
alexdon
Paysdoc
OK. Yes the folder is on home screen.  I tap on the second screen when the folder is opened and now i can rename ! Thanks.
